Old 03-28-2020, 06:38 AM   #11
jsceash
jsceash's Avatar
Y'all running the softronic: that passes your local emissions? Or are these track cars?
PA does minimal test ECU codes and sniffer as long as O2 trace is good car passes. I'm still street-able and passed inspection 3 years straight with my set up. 3.6L, 987 Airbox, 110 mm silicon connector pipeand reducer, 90mm MAF, 74 mm TB, IPD Plenmun (pebbled style). Pollished ballanced crank. H-beam carillo rods. 12.2 Compression ratio, #1 O2 i catless header, #2 O2 after 200cnt mid-pipe cat, Modified Special Edition Softronics Program. Edited fuel curve and map air for displacement. compression and MAF volume
