Old 03-23-2020, 10:22 PM   #2
thstone
Here are some general responses. We could create an entire new forum dedicated to this subject!
Originally Posted by Robert986 View Post
1) ADAPTION
I take it that the DME adapts to a certain amount of change in airflow after a improvment of intake or exhaust. This "adaption" is that reffering to the adjustment of fuel-input that is made by the short term fuel trim and after a while moves over to long term fuel trim? Or is it the actual fuelmaps that changes by some kind of magic?
The OEM map is static, meaning that it doesn't change. Its hard programmed into the DME.
The DME monitors the O2 sensors and makes small adjustments (up and down) in air/fuel mix to find the optimal point. This is short term fuel trim.
The long term fuel trims are averages of the short term trims.
Trims are stored in non-permanent DME memory and will be lost if the DME is reset (and then adaptation has to start all over).
2) MAF CALCULATIONS
As discussed in other threads, when using the 987 MAF-tube the DME doesnt know of the larger area of the 987-tube and calculates to little airflow leading to a lean state. If I have understood this correctly a pro tuner will be able to adjust this in the DME. How is this done? Is it a simple constant in the DME-calculation that is adjusted to represent the new area or are the whole fuelmaps adjusted?
The pro tuner will create a new map by monitoring the air/fuel mixture using an exhaust probe while the car is on a dyno to find the optimal performance at varying engine rpm, loads, etc. This new map will be written into the memory of the DME, creating a new map.
Typically, the entire map will be replaced but some points in the new map may be close to the original map. It really depends on how aggressive the tune is and what changes were done in the engine (differing from stock).
3) MAPS
A very wild guess is that there are three states of operation:
a) Startup/Idling: I would guess that this is managed by a fixed map in a open loop condition.
b) "Middle ground/half throttle" I guess there is ONE singel fuelmap covering this area operating in "Closed loop" thus adjusting STFT/LTFT based upon feedback from the o2-sensors.
c) WOT (Driving like a man) I guess this is covered by a separate fuelmap operating in open loop.
d) Finally I guess that also the ignition is managed by separate maps just like the fuel.
Its more complex than this. There are at least two start routines (cold start and hot start) that have different parameters within each routine depending on the monitored variables.
Start is open loop, warm operation is closed loop, and WOT is open loop.
Yes, ignition timing is map-based just like fuel.
4) CODE/PASSWORD
Is there a password to get into the Motronic that we need to get from the dealer? Then how do the pro tuners do? I have got an offer to tune my car and I donīt think they need a code from the dealer.
Some tuners hack the DME and re-progam over the existing data (its really not that hard). Others will piggy back an external controller onto the stock DME to intercept the signals from the stock DME and modify them before they are sent to the engine. Or some tuners will replace the stock DME with an easy to program/modify aftermarket unit.
Go and buy this book:
https://www.amazon.com/Bosch-Fuel-Injection-Engine-Management/dp/0837603005
