Old 03-15-2020, 11:45 AM   #24
thstone
Originally Posted by MaxD View Post
With the stock or any aftermarket slider the seat may be a bit high for some and you may not pass the "broomstick test" with the stock roll bar.
Yes, this can be a problem for taller drivers (I am pretty average in height at 5'10"). The easy first step is to modify the mounting holes in the BK mount to lower the seat. That can probably buy an inch or so.
Of course, there is only so much adjustment that can be gained from off the shelf components, so if you're as tall as a sasquatch, then you might need to delete the slider entirely or create a custom mounting solution.
