Old 03-12-2020, 09:09 PM   #21
thstone
Question:
When you took the plunge to put a fixed position racing seat in your street boxster, did you also do a roll cage? And did it remain your street boxster?
I'm wondering how a racing seat will get along on the street.
No, I installed racing seats and harnesses without a roll cage. I used the stock 3-pt belts when I drove on the street and the 6-pt harness when I was on the track. Otherwise the car was stock (see photo).
The only problem with a racing seat on the street is that you have to lift your butt up to get over the tall side when you get in/out. Also, it might take a little practice to get the seat belt into the stock seat belt receptacle (which is between the tall seat side and the center console. Otherwise, it worked great and was comfortable for even 6 hour drives.
This seat was installed using the stock slider and a Brey-Krause seat mount (adapter).
The harnesses hadn't been installed yet when this photo was taken:
