Thread: IMS question!!
Old 02-15-2020, 10:04 AM   #3
JFP in PA
Maytag is correct; once you have stressed the bearing by trying to pull it, it has to come out and be replaced. Doing otherwise is courting disaster.
If you used the idiot set screw method, I would bet you do not have the engine at TDC with the cams locked, which means that the shaft is now off center in the flange opening, which puts you in a very bad situation because it is now very difficult to get the engine into the correct rotational position to remove the bearing.
