Old 02-08-2020, 09:13 PM   #16
steved0x
steved0x's Avatar
The 987 is a little different in the front, the lower spring perch is a little higher which may mean the pinch bolt that holds the upper end of the sway bar link is a little bit higher too. From looking at your picture, yours are juuuust barely too long, like maybe 3/4"? So maybe it would work on a 987? I'd be happy to make a measurement on mine and compare with my 986 (both on stands at the moment), but if you ordered the tarett already you have it covered and I think you'll be happy with them, they are what I am running.
