Old 02-02-2020, 08:05 AM   #1
KevinH1990
KevinH1990's Avatar
I recommend that you take a look at this post:
Headlamp connector/socket pin help?
It shows the pin assignment on the headlight. Use the ground (-) from a 12-volt power source to connect to the ground. Then use the power (+) from the 12-volt source to connect to each power pin. (I use a 12-volt power source that I removed from a broken personal computer for this type of work, but you could also use a car battery.)
If the headlight works, the problem is either in the way the headlight is seating or somewhere in the car wiring or the headlight switch.
If the lights don't work off of the 12-volt source, the problem might be in the internal wiring of the headlight. German cars from this era used a biodegradable wire insulation which fails fairly often. You can find some information on this post: Advice on Used Litronics
