Old 01-30-2020, 12:44 PM   #13
steved0x
steved0x's Avatar
Originally Posted by Rom View Post
I wanted to close the loop on this thread in case anyone looked at it (annoys me when I see threads with no solution posted!). The sound ended up being the rear passenger side top mount - the rubber has sheared completely so the suspension was moving freely up and down over bumps, knocking loudly. It didn't fall out because of the large washer on top of the damper, but was surprised how the rubber completely failed.
It was a brand new OEM top mount when the suspension went in, but of course the suspension being much stiffer put a much higher load on it.
Thanks!
S.
I've seen this happen twice now, but only in cases where the lower cupped washer was failed/forgotten to be installed - the OEM strut top mounts require both the upper and lower cup washers to hold in the rubber bushing and give it something to push against for compression and rebound loads. If the failure looked like this, it is from a missing lower cup washer, you can see the top washer in this photo.
