Old 01-20-2020, 02:07 PM   #5456
Qingdao
Qingdao's Avatar
Originally Posted by alynch View Post
Re-installed the headlights after having them sanded and clear-coated locally based on a recommendation from a fellow forum member (thanks dghii). The wiring for the turn signals crumbled when I pulled the headlights out so while they were being reworked I dismantled the connectors and replaced the insulation with heat shrink. Before re-installing, I peeked inside the headlights to check all the other wiring fearing it might also be crumbling. Yaah! Everything looked good. Well, that was until I started to replace the parking signal bulbs. The wires crumbled if you looked at them much less touch them. So, for the moment I just taped up the exposed wires with electrical tape until I can find the time to disassemble everything and either replace the wiring or cover with heat shrink.
I know, I know. I should have stopped and repaired the issue properly. But sometimes I just want to drive the car instead of always working on it. Can you ever get ahead of the maintenance on this car? Just venting ......
Man, I am doing the exact same thing. Except my box doesn't even run so I'm going to re-solder all the wires.
On the plus side my clear came out FABULOUS. Only a spec of trash in the amber section, but other than that its flawless. Kinda bad because now you can see the imperfections on the inside of the headlights.
^^^ before
^^^ The PO's "upgrade" for HID. LMAO yeah that screams fire hazard. Even has a little kindling paper for when the wires short and get hot.
Photos don't really do justice. This is some pretty good paint work.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
