Old 01-20-2020, 12:31 PM   #5454
alynch
Re-installed the headlights after having them sanded and clear-coated locally based on a recommendation from a fellow forum member (thanks dghii). The wiring for the turn signals crumbled when I pulled the headlights out so while they were being reworked I dismantled the connectors and replaced the insulation with heat shrink. Before re-installing, I peeked inside the headlights to check all the other wiring fearing it might also be crumbling. Yeah! Everything looked good. Well, that was until I started to replace the parking signal bulbs. The wires crumbled if you looked at them much less touch them. So, for the moment I just taped up the exposed wires with electrical tape until I can find the time to disassemble everything and either replace the wiring or cover with heat shrink.
I know, I know. I should have stopped and repaired the issue properly. But sometimes I just want to drive the car instead of always working on it. Can you ever get ahead of the maintenance on this car? Just venting ......
alynch is offline   Reply With Quote
