Old 01-13-2020, 03:38 AM   #6
Tremonte986
That's the variocam actuator. You will need a set of timing tools to replace this. It's quite a task to change this with the engine in the car as it will require removing bank 1 to access everything. May as well have the tensioners and pads replaced as well if going that deep.
Tremonte986 is offline   Reply With Quote
