Old 01-09-2020, 03:54 AM   #723
Starter986
1998 Boxster Silver/Red
Originally Posted by BFeller View Post
Here is what remember from the last time: Fred sent a new panel, LED strip and control box. You would remove the plastic frame from your old panel - so you needed the original wind screen to start. You put the led strip in the bottom of your frame and then install on the new Skybreaker. Then run the control box to some power connection in the center console, followed by connecting the control box to the led - via routing the wire run under the carpet behind the set and the trim around the b pillar.
Gotcha. Thanks!
1998 Porsche Boxster
