Old 01-08-2020, 02:12 PM   #721
BFeller
~ 2 bills? I'd be in.
I'm assuming, correct me if I'm wrong, that the part will be a plug-and-play... and that we'd be removing our existing windscreen and plugging in your part? Or... are we sending you our existing windscreen and you're fabricating on top of that?
I'm thinking if you're selling the complete package one might just sell their existing windscreen making the purchase of your part a no-brainer. You know... offset the expense of the "cool" part by selling the "boring" part.
Thanks!
Here is what remember from the last time: Fred sent a new panel, LED strip and control box. You would remove the plastic frame from your old panel - so you needed the original wind screen to start. You put the led strip in the bottom of your frame and then install on the new Skybreaker. Then run the control box to some power connection in the center console, followed by connecting the control box to the led - via routing the wire run under the carpet behind the set and the trim around the b pillar.
"YouTube Certified in Various Specialties"
