Originally Posted by particlewave
PW: I have a 2003 Boxster S (new to me) and everything is working fine, including the key fob. I am planning on leaving the car while on vacation for about 4 weeks and then again for several months. My plan was to disconnect the battery totally by removing the negative cable. Beforehand I would drop the windows a bit and open the front trunk lid (and set up that latch mechanism so that the lid could not inadvertently close shut). I would leave the car unlocked in my garage. I would then return from vacation, reverse everything and hope that everything works. The car has an aftermarket radio (Kenwood) which does not have any type of code in it to reset.
Does this plan sound reasonable to you in terms of trying to keep the battery from totally draining down while I am away? Thanx in advance for your advice and counsel.
