Old 12-24-2019, 10:26 AM   #2
thstone
Originally Posted by YellowBoxster951 View Post
Looking at the sprint booster now. Wondering if maybe the softronic tune will do the same thing.
The sprint booster simply remaps the throttle so it opens much further compared to the amount of throttle pedal movement. Thus, it tricks the driver into thinking that the engine has much more power at throttle tip in - wow, I just touch it and it really goes! You can achieve the exact same response by simply pushing harder on the throttle! And, of course, the actual engine power is unchanged so the greater response at low throttle openings has to come at the expense of less power at wider throttle openings (wow, I floor it and nothing much more happens).
The Softronic tune will actually produce slightly more engine power but will mostly leave the throttle sensitivity at stock.
