Old 11-27-2019, 06:45 PM   #21
Porsche54321
Originally Posted by ImInHeavenInMy987 View Post
Hey all, I did something stoopid...
I disconnected my battery before pulling the wiring harness of my passenger seat, and then closed the hood.
A quick google search found the method of attaching a jumper to the "hood-release terminal" in the fuse box. When I did this, it did release the steering wheel lock, however I still could not release the hood. My suspicion is that this isn't working because the battery is disconnected, as opposed to simply dead. Anybody know if this is the case?
I've also seen reference to the cable-release in the front driver's side wheel well, which you need to take the wheel off to access...
... and of course you need the tool kit to get the wheel off...
... which is in the trunk.
Is there something I'm missing here?
Thanks for any ideas.
Jon
You can remove the wheel well without removing the tire. If you jack it up it will give you enough space. Your maybe able to do it without jacking. There is a good solid spot to jack where a typical car manual would suggest.
Let me know what model Porsche YYOU have and what engine if you find the release Cable let us know where.
Could be on either side near the headlight ( two possible places to look)
Could be under the bumper
Could be around the fuse box.
Porsche54321 is offline   Reply With Quote
