Old 11-09-2019, 07:36 AM   #11
Ciao
Ciao's Avatar
Originally Posted by Oldcarguy View Post
Hi Ciao, because every build is different FSI doesn’t quote hp or torque gains in advance. We’ll have to wait for the dyno runs. Also, FSI is doing a custom 93 octane tune (included is their tuner which stores up to 5 tunes). They indicate that the custom tune will be more effective on my 550 SE due to the 987 intake parts and my Fabspeed mid pipes with the FVD Brombacher muffler. Probably minor improvements but worth the effort IMHO. So the dyno runs will reflect the sum of all parts.
The focus of the Stage 1+ engine is mid range torque more than hp. In any event, FSI says there is no problem with the stock 6 spd handling even their Stage 2 or race engines if the drivetrain is in good shape going in.
Thanks Oldcarguy. I believe the gains will be impressive and more cost effective in terms of buying HP for your current Porche than buying a new one. I hope the build is durable and longlasting. I've noticed typically factory specs w/out mods make for a long lasting engine 275K miles plus. But specing your engine from the bottom end up may be a better solution than just a tune or increasing intake/exhaust flows.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
