Old 10-05-2019, 06:45 PM   #2
particlewave
Well, there is no fuse, so it’s not “ok”
The lights receive constant 12V+ from the immobilizer (connector 2, pin 4, red wire with black stripe) and the ground is switched. Do the front and rear trunk lights work (they all have the same positive power source)?
If not, check for voltage at the immobilizer.
If voltage is present, you may need to do some digging for the break or short.
