Old 08-19-2019, 08:04 AM   #14
maytag
Who's askin'?
maytag's Avatar
Originally Posted by rastta View Post
Sure hope you are using the high heat locktite as regular blue or red will turn to liquid with enough heat and the studs will back out.
Studs shouldn't back out spontaneously regardless of loctite use or no, if the nuts are torqued properly. the only time studs without loctite should be able to "walk" out is during wheel-changing / nut-removal.
A properly torqued nut on a stud is at the same risk of coming-loose as a properly torqued bolt is.
