Old 08-19-2019, 06:22 AM   #13
rastta
rastta's Avatar
Also, the instal;ation instructions on some say to use red locktite. I used blue and have not had any issues. Red is considered "permenant" and probubly will require heating with a torch to remove.
Blue will hold them in, but you can break one loose if you have to with wrenches
If you track or AX your car, once you try studs, you won't want to go back to lugbolts. Makes tire changing super easy and fast.
Sure hope you are using the high heat locktite as regular blue or red will turn to liquid with enough heat and the studs will back out.
rastta is offline   Reply With Quote
