Old 10-05-2006, 01:48 PM   #2
insite
the radio has two fuses: one for the amp power and one for the LCD display. the LCD fuse shares a circuit with the 12V power outlets (one of the aux. fuses). were you able to see your code after you reset the battery? if not, your aux fuse is likely bad. test it with a meter even if it looks good; sometimes a fuse looks fine but has blown.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
