Old 07-03-2019, 04:05 PM   #7
1PorscheBoxster986
A Porsche Guy
1PorscheBoxster986's Avatar
I ran into this situation when I did an aftermarket radio install. I removed the negative/ground terminal and shut the hood. I had to go on my passenger side wheel well to find my emergency frunk wire. It was tough to get to but I found the wire and with just my index finger wrapped around my thumb I yanked it. There was slight tension pull but once I heard the pop sound I was good to go. It should not be as difficult as you have made it seem. I think something is broken. I did not access it from underneath the car. I access it directly from behind the passenger headlight. Try to not pull the cable downwards but towards to the back of the car like pulling the door open. You are facing the direction like you're driving. That's how I did it mine. I have heard some people re-wire it near the tow hook. You can try doing that and then pull the wire.
1PorscheBoxster986 is offline   Reply With Quote
