Old 07-02-2019, 03:11 PM   #1
gti13
Originally Posted by dsallean View Post
this might help as well:
https://986forum.com/forums/boxster-general-discussions/69281-where-does-go-vacuum-valve.html
When I removed mine for cleaning I had the line to the electronic change-over valve just hanging loose and it took a while to locate where it went.
Okay so Line G is if you have an Automatic transmission? if so I have a 5 speed Manual
L should plug into the passenger side throttle body pipe, ill have to look for this as I dont remember seeing this but I will double check
gti13 is offline   Reply With Quote
