Yep, graphite only, although this has nothing to do with the op's question.
Unless you just recently replaced the ignition switch, you're a complete idiot not to spend $15 to get a new ignition switch and replace the old switch if you're pulling the old ignition switch out to see if that's what's causing the hard turning of the key. If you can't cough up that $15, sell the car now.
2003 Boxster S
