not sure, but the switch is easy enough to replace, takes about 5 minutes once you squezze yourself under the dash. You need a small flat blade screwdriver to loosen set screw (DONT REMOVE IT) and it pops right in. Pedros Garage explains the entire procedure in detail.
search on amazon for 4A0 905 849B, the vw/audi switch to see significant savings...its the same part selling for 30-60 dollars under porsche badge.
