Old 05-14-2019, 11:32 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
I'm not very good at discerning noises in those typ of video, but if you don't know when the engine mount was replaced last, it would be a good idea to go ahead and do it.
Here's a good description of the job: https://www.pelicanparts.com/techarticles/Boxster_Tech/10-ENGINE-Engine_Mounts/10-ENGINE-Engine_Mounts.htm
I recently made a video: https://youtu.be/h0BQQymTRPs
Also make sure that your power steering fluid is at the correct level and filled with the right fluid: Hydraulic Fluid CHF 202 or equivalent.
Anther 'grinding in turn' noise could be a wheel bearing, but I don't think that having the storage compartment lid open would make any difference in that noise.
