Thread: Roll?
Old 05-13-2019, 05:54 PM   #8
thstone
I agree, roll isn't your biggest problem. The first and foremost parameter to worry about is camber. The stock suspension (even M030) is hugely camber limited. Lack of camber is the primary reason the outer portion of the tire will wear (although roll contributes to running out of camber).
With the right suspension components and settings, its easy to get more than sufficient roll stiffness...
