Old 05-07-2019, 09:08 PM   #1
thstone
Start with camber, then increase tire width, then improve shocks.
What do the rules say about adjustable lower control arms?
I ask because the stock suspension is extremely camber limited - to the extent that if you can't run adj LCA's with the wider tires/stock suspension then the wide tires won't do much good and the narrow tires/coilovers might be the best route. However, if you can run adj LCA's with the wider tires and otherwise stock suspension, then that configuration might be a winner.
If the only way to get adj LCA's is with the narrow tires, then that route is the way to go.
