Old 05-06-2019, 02:38 PM   #630
particlewave
I applaud your efforts, Ben.
However, running a round aluminum ball against a flat plastic surface is going to leave you with the same issue: play will develop quickly as the ball wears a groove into the plastic sleeve.
You need something more like the stock insert for the ball joint in order to distribute the load.
