Old 03-29-2019, 06:08 AM   #4857
alm001
01101
Originally Posted by morgal48 View Post
I'd like to know about those screened vents you've cut in the fender liner. Can you share, please?
Sure! It's just expanded metal mesh from Home Depot. I used aluminum, I think it's intended use is for gutters.
  • I pulled the whole fender liner out
  • Determined the shape I wanted based on the bracing behind the radiator.
  • I cut the liner with a cutoff wheel. I wanted the corners rounder than they ended up. I used a 1/2" drill bit, it would have looked better with a full inch.
  • I had to cut out some of the original radiator shroud so the air could pass straight through. I used a hacksaw blade. A dremel would probably be better.
  • Cut my mesh to shape
  • Drilled some holes, and riveted it in place.
alm001 is offline   Reply With Quote
