Old 03-19-2019, 12:34 PM   #3
986bsdriver
So I finally figured out how the dealership did the DRL installation so clean. They hid the relay just above the fuse box so it’s hidden under the panel. I barely saw the single wire that was zip tied after the fact as it blended in so well. After taking the relay out and taping the ends of the wires it’s good to go.
Can anyone confirm the operation of the headlight switch?
When the keys are on the ON position:
First click it will turn on the illumination.
Second click turns on the headlights/high beams
Keys in the OFF position
Second click does not turn on the headlights but with turn on once the keys turned to the ON position.
986bsdriver is offline   Reply With Quote
