01-25-2019, 12:58 PM
#1
Super Moderator
IMS Retrofit / Upgrade Products
If you're needing to upgrade or repair your IMS, check out these products below.
Please let us know if you have any questions!
- LN Engineering IMS SOLUTION for 2000, 05 M96 engines with original single-row IMS bearing. Replaces OE single-row bearing with pressure-fed bearing.
- LN Engineering IMS SOLUTION for dual, row IMS BEaring MY97-01. For M96 engines with original dual-row IMS bearings. Replaces OE dual-row bearing with pressure-fed bearing.
- LN Engineering IMS Solution Intermediate Shaft Bearing Update Kit, (updates from ball bearing to simple bearing with oil-feed)
- Pelican M96 Intermediate Shaft Bearing (IMS) Update Kit, for either Single or Dual Row IMS
- LN Engineering IMS Bearing Single Row PRO Retrofit Kit. Fits 2000-05 M96 Engines. Integrates dual-row bearing in place of single-row bearing.
- LN Engineering IMS Bearing Upgrade Kit for M96 2006-08. Engine disassembly required.
- LN Engineering Dual Row IMS Bearing Retrofit Kit for M96 1997-01 (inc. hub, retainer, and bearing)
- LN Engineering IMS PRO TOOL KIT. Everything you need to install a classic Single or Dual Row IMS Bearing Retrofit. Includes: Bearing Installation Tool, 5 Chain and 3 Chain Engine Cam Locks, TDC Lock Pin, and Broken Stud Easy-Out
- LN Engineering M96 Faultless IMS TOOL KIT for removal and installation IMS Bearing retrofit, (kit #LN-106-08-2-2)
