Old 01-24-2019, 08:17 AM   #10
Blackroot
Originally Posted by dachrist View Post
I guess what I mean is that you still had to fab up some sort of connection between your new radio and into the Optical box you purchased off of Amazon, which then plugged into the Bose amp?
Once you unplug the factory cdr23 radio (in my case) optical connector, that same connector plugged directly into this new bypass optical box. You then wire up the red, yellow and black wires from the new box (B+, ACC and ground), and then hook the RCA jacks to front left and rear right from your new radio RCA outputs.
Blackroot is offline   Reply With Quote
