Old 12-28-2018, 01:19 PM   #2
Blackroot
Originally Posted by Oldcarguy View Post
I’m on my iPad and I thought I read your whole post, but I missed your very pertinent point at the bottom. Those 4 pot calipers are holding a lot of fluid under extreme braking. Also, I have no records indicating that the fluid has been changed in the last few years so there may be who knows what in the system.
I’ll try to change the fluid and purge the brake and clutch systems next week. I’ll update as soon as I have the result.
I just used one of these with fantastic results. I did it dry @ 22PSI
https://www.amazon.com/Motive-Products-European-Bleeder-Pressure/dp/B0002KM5L0
Be quick on the bleeder or you will drain the brake fluid tank.
I'm a weekend warrior, like you
Blackroot is offline   Reply With Quote
