Old 12-27-2018, 10:06 AM   #3
thstone
There are many components that can create symptoms similar to "limp mode": bad throttle pedal sensor, bad MAF, clogged fuel filter, bad fuel pump, dirty fuel injectors, problems with wiring/connectors, partially blocked/clogged air intake, etc.
I've experienced similar symptoms on four different occasions due to bad MAF, disconnected MAF, clogged fuel filter, and a partially blocked intake.
As Anker suggests, check for ECU codes first using a Porsche specific reader. If there are any codes, post here and someone will help you with diagnosis. If no codes, then you'll have to systematically work through the various possibilities one by one.
