Thread: Chain noise?
Old 12-20-2018, 04:50 AM   #10
key_lime
key_lime's Avatar
Originally Posted by Boxstard View Post
... I am hearing what seems to be chain noise when giving very little throttle at low rpm....
Hi Boxstard,
The issue you describe sounds very similar to a noise I’m experiencing. I also have a 1997 2.5L.
Every time I ‘feather’ the throttle, either gradually on or off, I hear a distinct ‘chatter’. Full throttle / No throttle and the noise disappears. Most of the time I hear it when attempting to maintain a steady speed when cruising, but it's amplified at high RPM's when easing off the throttle after a hard acceleration (when joining a motorway for example).
Interestingly, unlike you - I can replicate the noise with the clutch fully depressed and the car stationary, by carefully holding the revs around 2,500 RPM and slowly feathering in a little more gas. Are you sure you can’t achieve this ?
I’ve just had my front engine mount changed (for unrelated reasons) which made no difference to the noise.
Did you ever find a root cause?
key_lime is offline   Reply With Quote
