Thread: stuck door
Old 12-15-2018, 01:53 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by ray_pilot View Post
My 98 boxster door locks have never worked. The remote does nothing and locking with the key only locked the driver's door. Locked it recently and now the door will not unlock. How do you open a stuck door? Will pull the panel and see what's broken inside but need to open it first.
If you unlock with the key, and keep it in the open position, will the windows go down?
If yes, try to use the inside lever. If the inside lever doesn’t work as well, apply light pressure with your body on the door, and then try to open it from the outside.
Once the door is open, don’t waste your time. Replace the locking mechanism.
