Originally Posted by Gilles
I believe that the rod bolts can be upgraded but the rod caps cannot be swapped as you mentioned.
ARP Bolts are an upgrade but the caps can not be changed or interchanged. The carrillo rods are stronger, but better yet they are lighter than the stock rods. The Original rods vary in weight by several grams. My set of Carrillo rod were within .5 grams of each other.
