Old 12-13-2018, 01:38 PM   #11
Blackroot
Originally Posted by BFeller View Post
I should have been clear - rotate the pulley until you get the cams to rotate 180 degrees.
Look at this thread> O-ring replacement on the IMS cover..?
Check the picture in post 21
Thanks.
I have them lined correctly, just need to wiggle the crank and get the cam lock tool in.
If i cant get the pin in the crank pulley hole, what about putting the flywheel back on and locking that ?
Just a backup plan
Blackroot is offline   Reply With Quote
