I actually just finished purchasing all of the parts when Sunset was doing 20% off everything last week. I already have the relay and plan to combine the left and right radiators to run on high only (since the low fans run with the AC, and the temp range where you want to trigger the fans manually means you are likely already running the AC).
My plan was to mount the relay behind the batwing where I plan to install the switch. It is a smaller relay than the standard ones in the car, so mounting it in the relay panel would require fabricating a custom mount, I also prefer to keep the wiring in the same area.
I will do a full right up when I finally get the parts then get around to doing the actual install, which probably won't be for a few more months. I may add an extra lead for connecting the engine bay fan to the same switch, but that requires running a wire from the rear trunk to the cabin.
