Where do plan on mounting this relay.......I have wondered if these can be mounted in the relay rack behind the fuse box somehow. There will one of these for every function and things could get really busy. For instance one might want:
-left rad fan switch
-right rad fan switch (or combine with above)
-engine bay cooling switch
-oil / trans cooler fan switch
-iPad charge power disconnect etc....
Is there one module commercially available to connect various accessory loads, and then have them controlled by the appropriate 986 momentary contact switch? This would make things easier for changes and or adding functions....You would just have to mount one oblong box
986 00S
