Old 11-29-2018, 08:00 AM   #11
Cunningr
Cunningr's Avatar
Originally Posted by morgal48 View Post
You will be disappointed if you are using the factory amp with a new head unit. The channel to the door speakers has an internal low pass filter that will remove frequencies above 50 Hz or thereabouts. It is possible to disassemble the Haes 6-ch and "remove" the filter. The procedure for that is on Rennlist, I think. There are also schematics for the mods necessary to the door cards to accommodate 6.5" speakers on Rennlist. Not enough room for 8", but some have installed 6 X 9. Good luck.
I modified a pair of nokia door enclosures i go off ebay to hold 6.5 drivers in the door, added some air holes and sound dampening. Went with 3 inch in the dash and 1 inch tweeters. Alpine amp and found a bose subwoofer out of a cabriolet and modified that to hold a 8 inch pioneer subwoofer. HU is set to active mode sounds really good.
