Old 11-26-2018, 01:31 PM   #3
Starter986
1998 Boxster Silver/Red
You need to lower the front of the motor around 3" IIRC if you haven't done so. The bolts will then come out, you should have room to twist the mount around until it acomes out.
I removed the four bolts holding the yoke... and finagled enough to remove one of the long bolts.
I didn't lower the motor at all... but do have a jack holding it up. I'll lower it a bit... and report back.
Thank you.
1998 Porsche Boxster
