We have done it on a four post lift, but one with sufficient spacing to allow the engine to drop straight down on a lifting table. Trying this with the car hanging off the end of the lift is a recipe for a disaster, period. If the engine won’t pass between the ramps, do it on the ground or find another lift.
Or build ramps over the ramps? Pics would be nice, but 4x4s and 3/4 in plywood are moderately cheap and will carry a lot of psi.
I did mine with an air jack, lots of blocks of wood and tall jack stands, a reinforced furniture dolly, and a cherry picker that I previously had used to lift a V8 out of a dodge ram. In this case, I used the cherry picker to lower the engine out the bottom.
First time is difficult, it's really a puzzle and you end up going back to correctly disconnect things. And actually, it was a rather easy reinstall.
