Thread: Engine Rebuild
Old 11-21-2018, 01:50 PM   #11
jsceash
jsceash's Avatar
Turning the engine to Zero will take most of the spring tension off the cams. The valve cover acts as the bearing caps for 2/3 of the camshafts. Once removed the cams can be damaged if too much spring tension is left on them.
