Old 11-20-2018, 04:34 PM   #1
thstone
How bad is the rear main seal leak? If its just a seep (oil on the bottom of the engine but no drops) or only a couple of drips now and then, then you can probably live with it for quite a while. If its leaving drops on a daily basis, then it should be repaired. Dropping the transmission, replacing the RMS, and re-installing the trans should run around $1200-$1500 at an independent mechanic.
Same for the transmission pan leak. But this one is fairly easy to replace so your mechanic should be able to do it for much cheaper.
Its important to replace the CV joint boot if its torn or leaking. Your mechanic should be able to do that for much less than the dealer.
