Old 10-28-2018, 12:17 PM   #10
Falvisio
With the motor running, take a can of starter fluid and spray it on the connections/hoses where you suspect a vacuum leak. If the idle rises, you’ve found the culprit!
Depending on the model year, I think these sleeves can be in different locations.
Thanks for your reply. 👍🏼
Falvisio is offline   Reply With Quote
