Old 10-28-2018, 11:18 AM   #11
A8ked
A8ked's Avatar
The large rear window and defroster are a big plus for rear visibility and cold conditions. There are two small caps that fit onto the hardtop front guide pins, if you leave them off you will get rattles. The caps are easy to lose when removing or installing the top, but replacements are available. As others have said the three top latches are adjustable and hold tightly.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
