Old 10-27-2018, 05:45 PM   #1
dghii
This is my old car....
https://okaloosa.craigslist.org/cto/d/2000-porsche-boxter/6709785208.html
I have not spoke to the seller since he purchased the car from me on July 5th. He has added 6K miles since his purchase.
I owned this car for 10 years and have all the maintenance records since 2008. No, I did not do the IMS etc but the car was 100% great with no issues.
Someone should buy this car!! It is too much car for the money. Everything worked on the car...no leaks or weird noises. I can tell you that it is tempting to buy it back. I bought a 2003 911 Cab with 65K miles...got a great deal at $19.1K. It is a great car but the Box is (was) just as much fun for a third of the price.
I'm not posting this for the seller...I can't even remember his name. It's just that this car needs to be out being enjoyed by a new owner.
Garage kept? check
Top with glass window? check
Good tire/brakes? check
Coolant tank? check
Water pump/thermostat and coolant flush? check
All fluids up to date? check (with the P stuff for coolant and gearbox)
plugs, tubes, O-rings? check
Ignition switch, headlight switch? check
wheel bearings, drop links, outer tie rods, front control arms, rear track arms? check
You get the idea....
