Originally Posted by robdelorenzo
Sorry to jump in to the conversation late, but is it possible to add the on board computer to an 02 Base? If so, what would I need to do this? I am intrigued with the idea, if it's possible.
Thanks!
You can add it, you need to either buy the stalk or put a button in somewhere. The OBC function then needs to be activated with PWIS or a Durametric Pro might be able to do it also. There are lots of threads and a Pelican article on it. If you do it, the PDwight harness is worth its weight in gold, I did it and didn't screw anything up. Be sure to have some good reading glasses to count the little terminal spots so you clip in to the correct ones on the back of the gauge cluster.
If you don't have cruise control you can add that too, but then you need to buy the three or four stalk unit and remove the steering wheel to install it.
